Eyecu thank you for reporting 🙏
thanks, Ill update that now for the next version.
Eyecu Services - Resource Allocation gives and error.
This is resolved in the upcoming update.
This is not currently doable without storing the hostname info in each container for user, since its phpmyadmin per user. There is a workaround to use another separate phpmyadmin instance for all users: https://openpanel.com/docs/changelog/0.2.2/#phpmyadmin but that will not affect the autologin, and it will still use the IP instead of hostname..
I'll definitely look into it when schedule allows. https://github.com/stefanpejcic/OpenPanel/issues/156
Eyecu Just couple small things so far, overall awesome panel and great work
thank you!
