I had a problem installing a small VPS (1core, 2gb, 20gb, ubuntu 22.04) where the error was that the mysql docker container wasn't being created.
https://discord.com/channels/1205652108213485568/1205652108213485571/1250190455501619280
After using --repair in the installation, that issue was fixed and the installation was successfully finished.
After that I decided to create a somewhat larger server to test in Hetzner this time with Debian 12. The only things I did to the server were to create a non root user, disable root login with password, change hostname and change timezone. I also opened some ports on the hardware firewall (I couldn't find a list of ports to open in the docs)
After that I tried the installation and I got the same error than before
ERROR: Skipping creating swap space as there already exists a swap partition.
Waiting for MySQL to start...
ERROR 2002 (HY000): Can't connect to server on 'localhost' (111)
SQL file import failed or database is not ready.
Error: Installation failed!
I'm sharing the report generated with the opencli public command.
http://support.openpanel.co/server_info/TdCjz51lxL62oUL3CXpLXXc6C6fEkrviMWFW0HkljGreww5Dc4NjAZuNTjim.txt
This is a test machine. If you want access to the server to I can reformat and give you access to test.
Regards.
