Hi
When I try to install Open Panel in Ubuntu Server 24.04, the installation fails with:
docker: failed to register layer: devicemapper: error running deviceSuspend dm_task_run failed
See 'docker run --help'.
Error: Installation failed! Failed to start docker container for MySQL.
If I try to reinstall OP, the installer exit with message: Error: You alredy have OpenPanel installed, but isen't true, becouse isn't impossible to run any opencli command in terminal.
Installation Issue
Hello, what steps did you follow for the installation? I didn't have any problem at this level but it is true that I did not try to install version 0.1.7. Have you tried with version 0.1.6?
Thank's for reply. I try to install OP with command bash <(curl -sSL https://get.openpanel.co/)
the server is a test vm in virtualbox 8gb, quad core and 240gb disk and for any installation tryed i have used an a fresh installation of ubuntu server with default option whitout preinstalled package. How i find a 0.1.6?
Hello, than'ks for answer. I finally solved it with version 22.04 but I didn't have time to write it. The problem is docker not supporting ubuntu 24.
- Edited
Send Hello again,
We added support for Ubuntu24 - but without disk quotas since device-mapper is still not working with docker on Ubuntu24. This basically means that all users have unlimited disk usage, so I recommend it only for VPS and private use.
Debian12 and 11 are now also supported, with quotas.
rjvishwa strange, we dont use devicemapper anymore
Can you share the output of install log here or for faster resolve, can you send the server logins on info@openpanel.com and I'll take a look
