Symptoms:
Docker service fails to start with error:
failed to start daemon: Couldn't create reference store repository: invalid character '\x00' looking for beginning of value
Problem
File /var/lib/docker/volumes/metadata.db was deleted/truncated.
Solution:
There is no way to recreate the file, restore /var/lib/docker/volumes/metadata.db or /var/lib/docker.img from a backup.
